awol
I posted about my 3YM20 running on 2 cylinders a while ago seeking advice on whether continued use was wise. Well, after 2 months of apparently trouble-free running - the diesel feed to the zero compression cylinder had been rerouted to the tank return - I lifted the engine and found an explanation!
My assumption for the cause is hydraulic lock due to sea water ingress through an open exhaust valve on No3 cylinder. The problem arose (I think - 'cos I heard nothing) after an enthusiastic spinnaker run from the Ross of Mull and up the Sound of Kerrera to Oban (some 30nm) with a following sea. Why this was a problem on a 42 year old boat that has had the same exhaust system with originally a 2GM and now a 3YM20 and has sailed many thousands of miles I don't fully understand but I certainly want to prevent it happening again.
Solutions -
I now await your verdict on why it will all go wrong!
Solutions -
- a high rise exhaust mixer - there is no room below the cockpit floor
- a larger waterlock - the one fitted is (I'm guessing) about 5 litres - at least the engine is out but the space is tight.
- a flap valve exhaust exit - exit is under the counter - would this work?
- a 50mm plastic ball valve to prevent in-flow but would need discipline to close and open it - would trying to start the engine with the inlet cock open and this closed cause the backfill problem I'm trying to solve?
