ean_p
does anyone use one of the cheapo ebay hydraulic crimpers and are the of any use........?
I couldn't agree moreI don't buy into the idea of one size down and don't crimp all the way, idea...
Is this perhaps because the tube terminals being used don't match the tooling... maybe the tube terminals have a thinner wall than the ones intended for the die have.
To be honest, a mechanical tool, with the correct die to match the terminal (which must also match the wire) should easily crimp 100mm sq in one squeeze.
It sounds a bit like guesswork if the lugs are of unknown origin (and maybe don't match the tool or even the wire), and you're then having to guess how much to compress.
The die, when properly matched to the tube terminal and the wire should close all the way. No guesswork involved.
That is the main problem; I bought one and a box of cheap crimps and it's as you say, the lugs are a bit approximate. Proper lugs from a reputable supplier are a different matter.I don't buy into the idea of one size down and don't crimp all the way, idea...
Martin, you are of course quite right. The last hydraulic crimpers I used were supplied for crimping terminals on military helicopters. Lovely fit on the lugs and a great crimp every time. I dread to think what they cost, but out of my budget.I don't buy into the idea of one size down and don't crimp all the way, idea...
