Huntsman 28 for sale/make good firewood.
burgundyben
28 Nov 2002
Niton Radio
Thats it, I've had with that rotting pile of unreliable junk. Its been threatened with a copy of boats and planes and a chainsaw and if it does not start to behave in the very near future it will be chopped up into little bits.
<hr width=100% size=1>Sod the Healey - I think I'll buy an E-Type.
Solitaire
25 Jun 2001
Southampton
Oh, the frustration of boat ownership. I know how you feel. Right, I'm off to pick up the "new" engine now. Round trip of 400 miles half of which will be towing 1/2 a ton of diesel engine plus outdrive. Better bloody well work!
ccscott49
7 Sep 2001
Oops! Something amiss young man?? "Nobody said it was easy, but nobody said it would be so hard" in the words of a popular cold play song! Fancy threatening it with a chain saw, tut tut, you naughty boy, now it will never behave itself!
burgundyben
28 Nov 2002
Niton Radio
well if it never behaves again it will be maintaining the current status
livid
furious
burgundyben
28 Nov 2002
Niton Radio
well apart from the mysterious water leak only when boat is in use that I cant trace, the diesel leak on one injector pump, the main problem is that saturday, doing bout 20 knots, only a couple of miles out of Hamble hit something in the water, could not see it, but now got bad vibration on one shaft, think I must have bent a prop or shaft
bugger, soiunds like Ian Ainge had a worse day than me tho
ccscott49
7 Sep 2001
Now, you can't blame the boat for hitting something it is old and may need glasses, have you considered that? Sounds ominous though. Water leak, from the hull or inside. Diesel leaks, well we all have them occasionally. By they way, you'll need lots and lots of pennies if you buy an E type, I know, been there done that, couldn't afford the "T" shirt! A healey is a cheaper bet.
ccscott49
7 Sep 2001
Now, you can't blame the boat for hitting something it is old and may need glasses, have you considered that? Sounds ominous though. Water leak, from the hull or inside. Diesel leaks, well we all have them occasionally. By they way, you'll need lots and lots of pennies if you buy an E type, I know, been there done that, couldn't afford the "T" shirt! A healey is a cheaper bet. By the way, the beggining of water leaks as I'm sure you know, can be miles away from where they appear!
burgundyben
28 Nov 2002
Niton Radio
B1 is right, lanason is sandra, ian ainge had a crap day, nothing to do with sandra, hlb is probly pissed, hence the confusion.
ccscott49
7 Sep 2001
It has been known for me!! to be in that condition, but normally still at it from night before.
Col
14 Oct 2001
Berks
Never mind your vibrations............Wheres my pictures???
Seriously, hope you sort it soon, I gather Foulkes are lifting her.
<hr width=100% size=1><A target="_blank" HREF=http://www.arweb.co.uk/argallery/colspics> Cols Picture Album</A>
mtb
30 Jan 2002
Re: Healey\'s are much better
So easy to work on re welding . easy engines to rebuild hey I might even have carburetters ? for em.
So have you got an iffy seam, all the pounding the hull take's at high speed causes a lot of stress along the hull I'd be surprised if it didn't leak .
cheers
Mick
<hr width=100% size=1>One day son all this will be yours #### off I dont want it
burgundyben
28 Nov 2002
Niton Radio
remember its a one peice moulded hull of 7 diagonal layers, I reckon its coming form the strainers or coolers or something else.
