William_H
In practical terms humidity affects us and what we do or want in various ways.
In one way when our body is hot we perspire to cool the body. The evaporation and cooling effect depends on temperature of the air and relative humidity. So hot dry air cools us well while hot humid air means moisture can not avaporate easily so we stay hot. Likewise in cold air the relative humidity may be quite high meaning perspiration can not evaporate so we stay damp even though the cold air may cool the body.
In the case of the garage we are concerned that damp things will dry by evaporation and this requires a low relative humidity. Cold air may have a high relative humidity which means it will not take up much moisture so everything stays damp.
Also in the garage if warm air comes in carrying some moisture then when this air cools say at night time the cold air can not carry the moisture and it falls out like dew so things get damp. (from the cold we might imagine)
So to reduce these latter 2 effects in the garage we need to either raise the air temperature which will reduce relative humidity so drying wet things or retaining moisture in the air. However it can be inefficient trying to keep a garage warm when outside is very cold. Better is to remove the moisture from the air. A previous poster has explained how dehumidifiers work. To remove the moisture means the air can be colder but still tend to dry things or at least not drop moisture out of the air.
None of which is much of a problem here with 29 max today 35 tomorrow and low humidity. But I feel for you in UK olewill
