pvb
But you could have a bigger Hallberg Rassy in great condition for much less... PM me if you're interested in one of the last of the fabulous 352s.
So what is the difference? Is there any? Does A Malo,HR,Southerly have huge amounts of increased strength over the AWB.
Thanks.
And that's just between the new boats - the older ones (Bav/Ben/Jen) from 1990s to 2001 at least used veneered ply - iirc Bavs were one of the last to move over to iron on MFI furniture that seems to be the vogue in the "cheap" boats these days.The big difference between the likes of Southerly and the Swedes on the one hand and Bav and Benny on the other is the quality of internal fit out. Is it all veneered MDF or is there lots of expensive solid hardwood. Ironed on edgning veneers or solid trim.
I hope that isn't your anchor!
I'm sure that's true with regard to the hull's ability to support structural loads, but what about abrasion, particularly over a protracted period, e.g. when being pounded onto rocks. I saw a lightly built GRP yacht which had come off its mooring at Ravenglass and been driven against a low stone wall. The skin was rubbed through along the bilge and the boat filled and sunk. The laminate appeared to be very thin, about 5 mm or so. I should have thought a thicker laminate would have held out for longer and perhaps allowed the boat to be saved.I doubt it. There is no point in making hulls thicker than necesary - all that would do is increase cost and increase weight to achieve nothing. And these days the design technology is such that designers know where to put thickness and where it isnt necessary unlike the old days of making laminates thich and full of filler for safety.
.... I should have thought a thicker laminate would have held out for longer and perhaps allowed the boat to be saved.
Good show. Now there is only one thing left stopping me buying this boat:
http://www.yachtsnet.co.uk/boats/b57811/b57811.htm
.........Poverty :-[
For the vast majority of boats the chances of running aground on rocks is just about zero.
