Grehan
Using the formulae available on www.johnsboatstuff.com (jolly interesting if nothing else) I have determined that Grehan's hull speed is 6knots (through the water).
I understand about how the boat sits in the water profile when travelling through it and hence the 'ideal' maximum speed before more velocity becomes inefficient.
[well at least I hope I do . . .]
Ah, but what happens when going faster than 6knots?
Is that just kind of 'inefficient' (ie there's a lot of effort for decreasing result) and also that the boat tends to bury her nose into the 'hole' in the water? Or something else / something more?
Should the sails be adjusted (reefed) to reduce any excess speed effectively to 6knots?
Have I got the wrong end of the stick somewhere?
I'm not exactly losing sleep over this, but some illumination/explanation would be gratefully received. Merci beaucoup.
