SquanderedSavings
New Member
We are in the midst of updating the inside cabin of our 1997 Bayliner Ciera 2355 and I need to line a few areas with the foam-backed vinyl stuff. The area to be covered is the vertical sides of the seating area between floor and seats, which previously had the horrible carpet stuff stuck all the way up it. The new flooring will only go on the actual floor section, while the seating (currently being re-upholstered) will have those vertical panels re-attached, meaning it's only a small section running all the way around that needs to be covered by me. However, the part I'm struggling with is how to tackle the two 90-100 degree corners of the three-sided seating. A first attempt at cutting the vinyl to size resulted in an unsightly mess. One possible idea is to run a long continuous strip of the vinyl all the way along, sticking it to all three sides and not cutting it into three sections at all. Is that a totally daft idea? The other possibility I'm mulling over is whether to cut so there is a little excess vinyl, strip back an inch or two of the foam backing from each edge and fold them in. I plan to use this method where the vinyl meets harder surfaces but not sure if/how it would work at the right angle corners where vinyl meets vinyl. Any thoughts?
(Just to add, covering ply panels with vinyl to place in isn't an option because of the seating panels that will have to fit over the top half. Similarly trim strips would likely add too much bulk there too, as well as seeming like a somewhat odd feature there.)
Any suggestions gratefully received.
