Boater On Thames
As tilte mentioned. Need help! I should not use a big wrench to tight the venting screw!
My engines are Volvo TAMD61A. Just replaced all the fule pre filters and fine filters. I follow the manual instruction open the venting screw at the fine filter, hand pump until runing fuel, close the venting screw, pump another 20 or more. Engine started okay, but it will stop after a few seconds running. Redo several times, the same result everytime for both engine. So I think the fuel is not running. Is my operation correct or wrong? What can I to to solve it?
Sadly I break the port side venting screw when I do the last try just now. Can't find where to buy one!
Many thanks.
Many thanks.
