demonboy
Hi all,
Another 'basic' question. I've tried Calder but can't quite interpret the following whilst testing for a short:
What's throwing me is the difference he is establishing between the 'power source' and the 'equipment'. In this instance the power source (solar panels) IS the equipment, isn't it?
To expand further: I have six solar panels on two banks which may be flipped from vertical to horizontal (they're mounted as drop-downs from the pushpit). One is smashed with a perspex cover and still working but with some trapped water inside. I suspect the monsoon got the better of it in my absence. I think this may be my problem but I don't want to take the perspex off unless as a last resort. When the panels are connected to the battery via the regulator, sometimes they put in the correct amount of amps, but other times they are showing minus amps. Yesterday they were showing -18! If I disconnect just the positive from the batteries, they were still showing the minus figure.
Last week we had a problem with a short manifesting itself by making the guardrail gate get white hot. I hadn't noticed this until I burnt myself on it quite badly. Thank god that was the only injury but it's a stark lesson in the dangers of boat electrics!
How do I test for the short?
Disconnect hot and ground size of circuit at the power source and at the equipment, and insert meter in place of the equipment
