DickieT
Your Fluke meter is simply showing an AC voltage. Does this increase from idle, if so I suspect your tach is simply a form of voltmeter that will show an increasing reading with revs. Not sure how linear this instrument will be with engine speed. At least you have an output from the sensor and assuming the wiring to the tachometer is all sound it really leaves the gauge as the prime suspect if the overall system is faulty. Parts, I would imagine are very rare. How does your electrical generation work ? If by DC generator (dynamo) - it is a 1970 engine- you are a little stuck. If however by alternator, possibly a later up dating, why not fit a conventional tacho gauge ? Normally there is plenty of adjustment via onboard (DIP) switches to accommodate the number of alternator poles and pulley ratios to make calibration easy and relatively accurate. Good luck whatever you decide to do. Richard
