macd
Stern to might be taking it a bit too far
It might be an unusual case where you are, but not round here. The effect on max revs is drastic.
I(stern to a quay) might be an unusual case where you are, but not round here. The effect on max revs is drastic.
One good indicator of overpropped is when the engine won't achieve max power rpm with the boat securely tied to the quay.
That can be too much pitch or too much diameter/blade area.
It's underpropped if the boat speed is too low at max power rpm.
Are you sure? I think not. The load on the engine is so much that it won't reach max rpm. I know this from first hand. My boat used to reach maximum rpm of 3500 (with previous gear box and propeller; now I am overprop) but tied to the quay only around 3100.
I said 'max power rpm', not max rpm.
3100 may be about right?
Quite max revs @ hull speed is correct, i have mine set to about 150 RPM under max revs @ hull spdLittleSister;5476122[COLOR=#ff0000 said:]Surely it won't be producing maximum power if it's not achieving maximum revs[/COLOR]? I think the power curve for my engine, a Beta 14, is fairly typical. At max revs, 3,600 rpm, it can produce 13.5hp, but at 3,100 rpm it can only produce 12hp.
Surely it won't be producing maximum power if it's not achieving maximum revs? I think the power curve for my engine, a Beta 14, is fairly typical. At max revs, 3,600 rpm, it can produce 13.5hp, but at 3,100 rpm it can only produce 12hp.
...The eternal problem with boat engines (for displacement boats) is that the prop size is essentially fixed so it only fully loads the engine near maximum revs. Below that the engine is never fully loaded as the prop will not demand full power. So your engine at a good cruising speed of, say 2500 is only using probably 7 or 8hp but the maximum it could produce is 10 at those revs.....
So? Not sure what point you are making. It is the prop that moves the boat and demands the power from the engine. So you set the revs you want with the control and the amount of fuel (and therefore power) required to achieve those revs is provided by the governor. If the boat is moving, the amount of power required is lower than for example if the boat is stationary or meets resistance such as waves or a headwind. This explains why you may not get full revs if the boat is tied up and conversely if the sails are providing the power to move the boat, the power demand from the engine will be less. The latter scenario is one the causes of bore glazing as the engine might be running at highish revs but with no load.The torque to turn the prop is a function of its rpm and also the slip angle the blades are running at.
The torque needed to do 2000 rpm at 5 knots will be way less than to do 2000rpm at 2 knots.
