Polly1
I seem to have started quite a discussion about pressure. Yes the filler is more like 6 cm id.
There are no obstructions beyond water, I had replaced the breather system when I first noticed the problem as I mistakenly thought it must be blocked.
As for the pressure arguments I think that how a head of water pressurises a tank is less to do with its weight. It is the the difference in atmospheric pressure from the top of the column to the bottom. Imagine if I angled the breather at 20 degrees at the same pressure, it would fill to the same vertical height though the weight of the water would be higher.
If the atmospheric pressure changed so would the height of water (like a barometer, hey just thought of a new use for my problem!)
