How to remove searchlight?
ThrilloPads
17 Oct 2017
I've got a searchlight that I'd like to remove to lower the air draft of the boat. Ideally I'd like to do it in a way that I can quite easily place back in if I ever need to.
I have no idea how to go about doing this. Is there a bolt I can undo where I can slide it out? I tried undoing the big bolt (pictured), but there's an additional metal tube within.
Any advice greatly appreciated :)
Quick update - I managed to remove it over the weekend. The screw at the top didn't seem to have anything in it, I think maybe it was a place to insert grease? However, I finally worked out that if someone was holding the search light to stop it moving you could then unscrew the control handle. Once that was done you could just pull it out. Two person job :)
All done now, thanks for the help. Now I need to decide what to do with it!
