Bobs
New Member
Can anyone help? I have a Dehler 25 with a worm-drive lift keel mechanism. I have recently had an operation which means I'd like to find a way to power the winch as it takes nearly 200 turns to raise or lower! It's a great system apart from the effort - no worries about cables snapping and gravity sending the keel through the bottom!
The winch is on the deck just in front of the mast and uses a standard winch handle with a star-type drive. Question: would a reversible 18v right-angle power drill with a suitable drive fitting be man enough for the job? I don't know how to work out the power requirement but this would be an easy and convenient solution if it works, rather than wire up a permanent motor.
Winding down is quite easy, winding up a little harder so I am guessing I am not producing that much human power but is there a way of calculating the power requirement? A decent drill isn't too cheap so I don't want to waste money trying it out if it's a bad idea from the start.
