Poignard
What diameter is the compression post?
So's mine. I'm planning to make a kind of hardwood "plaque" to which the lamp can be screwed. There are some existing threaded holes in the post which look like they're from a previous lamp (not the same as mine though, so can't be used directly). I need to check whether the holes are in the right place to bolt the plaque into - but if not it's quite likely I will just glue it on. Sikaflex, no-nails or epoxy are all possibilities.
My post is square - is yours square or round?
Why not make a bracket to accept the oil lamp that has a couple of long feet or tangs and then atach said tangs to the compression post with a good tight whipping, topped off with a bit of fancy knotwork. If you want a bit of nautical atmosphere that would be a way to go and no holes in the post!
I like that.![]()
