CLB
I thought I Understood this until I looked into it further, I am now more confused than ever.
If a pump manufacturer provides a performance table for a submersible pump, is the 'head' measured from the pump, or from the water surface. ie, would it be beneficial to raise the pump from the bottom and closer to the surface for improved performance. I initially thought it would make no difference as the pump is only lifting water from the surface, but now I'm not so sure.
Also would the same apply if the pump was mounted outside of the tank but level with the bottom of the tank so that water in the outlet pipe was level with the surface when the pump is switched off.
Cheers
Cheers
