Sammy Lou
I'd appreciate peoples thoughts on how best to remedy my c*ck up.
Last weekend I removed the sails from the boat as I was preparing it for coming ashore and it was planned that the mast would be un-stepped for new rigging during lay-up.
However, during the course of this week, my plans have changed and I'm no longer planning on laying up the boat where she is and need to move her this coming weekend.
The problem is, as the boat is new to me, I was unfarmiliar with the forestay/jib halyard arrangement & as I untied a wire from on top of the jib furler it shot up the mast and the sail came down. The halyard wire is now 12m from the deck. I was expecting the jib to be secured by a sheet in the mast!
It would not of mattered if my plans had not changed but I now need to re-fit the jib & I'm considering my options for getting the jib forestay wire back to deck level.
I've thought of using a top climber (or similar) & possibly drain rods to hook it but does anyone else have any suggestions? I'm a bit worried by heights (understatement) and also concerned about the job having to be done whilst the boat is on its keel in mud.
Does anyone have any suggestions? The boat has to be moved this weekend, I'm unhappy to have motor only (althought the distance is only 17nm), I'll have the main but the reefing is not set up and I'd be happier with the furling jib rigged.
Thanks.
Thanks.
