Paddy Fields
Hi all
Is there any problems around furling in a mainsail in strong wind, and if so what are the tricks to make it easier?
Only used a furling mainsail a couple of times, and in fair conditions. Furling in the main was just a case of pointing into the wind and grinding it in, which was, well, quite a grind. It made me ponder if the same strategy would work under heavy winds, or would the drag on the sail make it impossible. Ive heard pointing slightly off to stop the sail rubbing against the mast will reduce the friction, but that clearly aint going to stop the windage on the main.
In strong winds, to furl a headsail if you point downwind, that seems to make it a lot easier (I'm not totally sure why). Is there a similar strategy for the furling main? Or is it is just a case of grinding it in, regardless of the conditions. Just a bit wary, since grinding in a headsail is a good way to break the headsail furling mechanism, and I have no feeling about what the breaking point is for a furling main.
Of course, reefing early might mitigate any furling woes, but what if the mechanism pops open, and it all unfurles "by itself".
Dan
Dan
