Gone sailing
I have a hollow wooden mast that is square and made up of four sections (one on each side) its 50 years old made of Sitca spruce.
This summer some of the seams have opened up which I have managed to fix with epoxy to get me through the season.
I now need to re-glue the seams. I guess the best way to do this is to break the whole thing apart and reglue not an easy job for me so I've thought of a plan B.
Not all of the seams have gone and the seams above the spreader are sound (although I've only inspected whilst hanging from the top).
Plan B....
Use as thin a saw as I can find and cut down each of the seams one at a time in maybe 1 meter lengths then glue as I go.
I would need some sort of gap filling glue to fill the saw cut so I thought I could use this flexible epoxy.
http://www.westsystem.com/ss/tough-flexible-g-flex-offers-superior-grip/
Doing plan B would mean I don't have to buy or find 300 clamps and would only need to do the areas that require attention which is basically the bottom half between the goose neck and spreaders. I would also not have to remove the goose neck and top fittings or worry about getting the thing back together straight.
Any thoughts on above would be appreciated.
Jim
Plan B....
Jim
