Sooshark
Active Member
Hi there
I did some work last summer and took my windows off, since putting them back on they now can condensation between the panes. It is two bits of plastic bolted on to steel, with the outside one sealed all around the edges the the rubber stuff you put windscreens on with.
How should I have put them on if I did it wrong... and also can anyone suggest how to fix? I’m thinking three little holes drilled in the bottom of the outside pane.
