How to fit Holt Allen HA 337 inspection cover.
Hardley
7 Jan 2003
Norfolk Broads
Recently purchased a Holt Allen HA 337 inspection cover.
Was going to cut the hole and fit it into the boat yesterday, first step is of course to mark the diameter for the hole, thought I would use the cover as a template, but the problem is that I cannot separate the two parts, have tried using wood and spanners that fit the slot, but cannot turn it at all.
Any one got any suggestions please.
Strathglass
Fife
It will probably unscrew if you immerse it into hot water for a while.
I always use a large hole saw when fitting round inspetion hatches. It makes a more precise cut.
Iain
Stork_III
6 Aug 2002
Here and There
110 mm cut out required.
ianat182
10 Jul 2008
,home Portchester
Vaseline or waterproof grease on the threads will make it easier to unscrew next time. As mentioned its a 110mm hole; I used a series of drill holes and dressed the aperture with a coarse glass cloth on a drum sander to get it smooth, but it produced a lot of dust/fibres.
ianat182
snooks
12 Jun 2001
Me: Surrey Pixie: Solent
www.grahamsnook.com
I just used a jigsaw for similar sized holes.
I tried this until I realised the area where the hatch was going wouldn't allow me to use a jigsaw
So.....I ended up doing this......
ianat182
And yes it does produce dust....but it works :)
Hardley
7 Jan 2003
Norfolk Broads
Well the hot water treatment did not work, about to send it back to Holt Allen, when her in doors picked it up, stuck a fork into one of the bolt holes and it opened, and I had struggled for hours with blocks of wood, large spanners etc, but now I can get on with the job of fitting it.
snooks
12 Jun 2001
www.grahamsnook.com
You weren't tightening it were you?:rolleyes:
Just thought that if it was upside down :D
