rszemeti
Whilst generally correct, it isn't entirely true that you "must" passivate stainless using either of the methods you describe. It's certainly true that doing so will cause the surface to be immediately passivated, but provided the surface is clean it will self passivate. If freshly welded stainless is cleaned and polished there is no need to passivate, it will self passivate. If it isn't cleaned it could be rusty the next day.
True, if you can adequately clean and polish the entire welded area and HAZ, then yes, it will self passivate, in practice, it is often difficult to get into the sharp corners where the weld meets the material and that is where the corrosion starts. In most cases. In a good TIG or MIG weld on stainless there should of course be no sharp crevices .. but it is usually better to get the pickling gel out, is it gets into all the tight spots.
We used to manufacture a lot of assemblies for oil rigs etc, and stanless tanks for breweries ... the electric weld cleaner was very handy for that.
