Babylon
I need to determine the pitch of our fixed three-blade propeller.
Any original data engraved on the boss has long since disappeared. Is it a black art, or can one work it out oneself?
Secondly, what is the convention for determining which way the prop is 'handed'? IE, observed from standing aft of the stern, the prop rotates clockwise in forward gear - does this mean its a 'right-handed' prop or vice-versa?
Finally, I assume gearboxes reverse the direction of rotation of the prop-shaft relative to that of the engine in forward gear. So, if the engine is rotating clockwise (when facing aft), and the propshaft rotation is reversed by the gearbox, then one would expect the prop to rotate anticlockwise when facing aft (ie clockwise when facing forward).
I need to know all this because, if I re-engine my Bukh with a Beta, I'd like to keep the existing prop if the two engines rotate in the same wise. - and Beta can then fit a bigger reduction gearbox (2.6:1 rather than the standard 2:1) to suit my existing, larger than standard prop.
Babs
Babs
