Skylark
I've just had a new chartplotter fitted within the steering pedestal. The drop-down, clear perspex engine control and instrument panel weather cover now requires trimming on one side only to accomodate the slightly raised backing plate of the new plotter.
The cover is 6mm clear perspex. I need to trim 10mm off the bottom edge of one of the side piece. An approx 7 inch long required cut.
The side piece measures 2 inch by the 7 inch required cut so there's not a lot of material to grip / hold firm. The major dimensions of the cover are approx 18 x 10 inches so it will be ackward to hold.
This is the (upside down) section |_____| I need to cut 10mm off one of the verticle edges, 7 inches long, if this helps you to visualise it.
I'm very mindful that perspect is very brittle and hence there's a risk of cracking.
Any useful suggestions how to take this cut and live happily ever after?
Many thanks
Many thanks
