Baddox
My lump of a diesel engine is suffering poor cranking and turnover at start-up. The batteries are OK but I’ve measure excessive voltage drop across the starter cables which I think is from the cumulative effect of mild corrosion on the connections.
To rectify this, I want to fit crimped lugs to the ends of the wire where none are currently fitted. I’d prefer to take the DIY approach and not relying on tool hire or taking the cables to a garage. So, does anyone have any recommendations of what works and what to avoid when fitting lugs to 60mm2 cable?
Options so far include…..
Solder- place flux into the lug, heat and melt a little solder into it, insert heated wire. Seems to be poorly regarded but no one is clear why.
Hammer-on lug made with a ridge to drive down the sheath onto the wire
Hammer-on die tool to crimp a lug in place on the cable for example
Reusable clamp-on lug
These look easily adjustable but next to impossible to cover with any shrink-wrap to protect from moisture.
Bite the bullet and spend a lot on a heavy duty crimping tool that I’m unlikely to need again.
