sailaboutvic
Once again I not saying what you post isn't correct .We do not use anywhere nearly as much as you and certainly not over night when the fridge door is not opened as often. We also do not have a separate freezer. Our fridge draws 4A; with a 30% cycle rate in our northern clime, that works out to about 16A over a 12 hour period.
300W of solar should, in theory, deliver about 1200W on average per day in our cruising latitude.
Having, pre solar, struggled to keep our banks charged we are suitably neurotic about the use of power and anything of importance has been converted to LED and we often use candle light in the evenings.
Our longest and most arduous drain on our batteries was when we sailed non-stop from Ijmuiden to Dieppe in 35hrs. This was done under sail only, running an electric pilot continuously, nav equipment and tablet (for Navionics), running lights, Webasto (at night), fridge (as usual, 24/7) water system etc The first day was overcast, the second sunny, sea conditions for the pilot, lively - there never was even the slightest hint of an electrical power shortage.
Thanks that clearer .
So basically your 300w is enough to keep up with you using 16ah and a little more give say for light and get your batteries back up to float by 10am
Here in the Med my panels are give me around 5A AT 8 am just looked now as I am writing this its a very sunny morning . So by 10am in my case I would had put 10A back in without whats taken between 8 and 10 am out plus a bit more as the morning goes on the panels would produce a bit more .
So my 400w panels wouldn't put back in the 16a plus the extra power needed to get my batteries to fully charge , although it may had replace the 16a that's been taken out .
I think when it comes to power management/solar panel it would be more help full it people said what batteries AH and usage they use over the day or at less over night .
I been reading on ybw how some people been getting some wild amount of amps out of the panels and been scratching what between my legs how they do and because of that I later been messing around with my panels getting them to the right angles to the sun for days and hours and can't get anything like that .
But the more and more cruiser who I speak to people as myself are all say the same ,and some have got some very expenses panels, you be lucky to get 2/3 out of a panel , which is what I found .
If I stay on anchor and not move so I am not using any other equipment,
I have to run my Gen for an hour each morning at this time of year In the Med on sunny days which probably amount to UK summer days to put back into my batteries whats been used since last fully charge ( when the panel stop charging last) plus what I been using during the time my panels been given me power on that day. And as I said its not till late afternoon my batteries go on float and there was a period for many days this didn't happen although I did replace the amps that been used ,
Which is not the same as the batteries being fully charged.
