halb
Is it possible to check a FM radio ariel using a multimeter, I ask as I'm installing one of the Chinese transponder and have an unused ariel on my mizzen mast, any advice will be gratefully received.
Is it possible to check a FM radio ariel using a multimeter, I ask as I'm installing one of the Chinese transponder and have an unused ariel ...
If someone is going to check the VSWR what channel should they use? Obviously not 16
Easiest way to check that an FM aerial is working is to plug it into the radio. I have not bothered with an aerial for years, a 2 metre length of wire works perfectly well, fed through a nearby locker.
I use 20 for new install checks and fault diagnostics, it's mid range so gives a good indication.
I believe the op is hoping to use what he thinks of as an FM aerial for his AIS transponder. Unclear what the aerial in question actually is.
