MapisM
That's exactly what I meant when I said "sealing filters and exhausts".In fact, their advice is to wrap a dustbin liner around the intake filters when the engines are not in use.
The big problem with this procedure is that you MUST remember to take them off
In fact, you're actually missing the and exhausts bit: the salty air problem you mention is even worse on the exhaust side, because that remains full of salt water, unless fully winterised.
Re. how to remember, when winterising the engines it's common practice to stick a memotak on the ignition key cylinders.
Aaargh!!! Now I must reconsider!MTU also recommended cranking the engines without fireing them.
Looking forward to Andy comments on this one.
PS: yes, on diesels you can keep the stop button pressed wihle cranking, to cut the fuel supply and avoid firing them.
On most smaller gasoline boats you can use the kill switch.
