D
Deleted User YDKXO
I can't see what the fuss is all about.
In the worst case, you can always turn on the genset and keep the battery charger running, so I would agree wholeheartedly with jfm that a non working alternator on one engine (or even on both at the same time - but how unlikely is it?!) ain't mission critical at all.
Yup you would think so, wouldn't you, but it didnt work like that on my Azi 46 or indeed my Princess 435.
When I had the Cat 3208 engine stop on me in the Azi 46 due to a faulty alternator, the first warning was the charging alarm going off. Naturally I thought no problem I'll just turn the gennie on to top up the batteries only it didn't work like that. The batteries continued to discharge whilst the both the engine and gennie were running presumably because (I'm no electrician as you know) there is some kind of switch which disconnects the battery charger if the engine alternators are connected to the batteries. Eventually as I've mentioned previously, the batteries discharged sufficiently to stop energising the fuel stop solenoid in its open position and the engine stopped
On another occasion we were cruising along the River Seine at very slow speed in our Princess 435 and the nav instruments started to malfunction. After a while I noticed that service battery voltage was very low and I guessed that the alternators were not man enough to keep the batteries charged at the very slow speed we were cruising at. Again I thought no problem just turn the gennie on but again the battery charger did not charge the batteries. After that we stopped every few hours rather than cruising all day, allowing us to shut down the engines and start up the gennie in order to keep the batteries topped up
So no starting the gennie is not an easy fix for a failing alternator or at least it hasn't been on 2 of the boats I've owned
