William_H
And this is how I drop the mast. It takes 3 to lower it, but about 5 to get it back up. I've dropped it several times and it always takes more hands to raise it again.
This picture was December, now, having fitted new standing rigging it's ready to go up again next week.
I am not surprised it takes so many people to raise the mast. That gin pole (is that what it is called?) should be seated at or near the base of the mast. Where it is set on the mast it seems to me is too high. As you pull on the forestay giving a downward force some of this force will translate to pushing the mast down in stead of lifting. It s all geometry and vectors of force and I may be wrong but I don't think so.
The other most useful trick is to have a A frame or post at the transom that is much higher so that you can lift the mast while standing in the cockpit as high as possible into the high A frame before you start to lift with the tackle on the forestay. Or have a tall person in the cockpit lifting as much as he can. The real load of raising a mast is in that first 40 degrees or so from horizontal. I have a single post clamped to the stern rail and sitting on the transom. It has a fork at the top about 2 metres but also a hook out one side much lower so the mast can be lowered right down. (by hand).
good luck olewill
