syvictoria
Hello! Can anyone tell me how much water (on average) it takes to flush a standard Jabsco Par manual toilet (not one of the eco flush electric models)? Thanks!
Thanks for this! Sorry, I'm being a bit thick... assuming the discharge hose is 1m and the diameter/stroke is 5cm, that gives me a final figure of 35 (20/5 + 5 + 10), but what does this mean? 3.5 litres? Sorry, told you I was being thick :-(
If I understand the OP he's struggling to convert the stroke value to litres.The diameters of the hose and the pump are almost the same. So if the stroke (the distance between piston down and piston up) is, say 15 cm, then the first figure is 100/15 = about 7, the full figure is then 7 +1 +2 = 10 strokes.
I recall that the handbook suggests seven strokes of the pump for every metre of outlet pipe run. This has more to do with ensuring that the outlet pipe is fully flushed to avoid blockages but it will however affect the rate at which your holding tank will fill.
