Greenheart
Pigging...
What is this pig/pigging matter? I'm completely in the gloom.
Pigging...
As an ex water company engineer, it infuriates me when ill-informed statements such as this are made. Water companies have already spent millions on leak finding and repairing. The majority of remaining leaks are below ground and not visible from the surface. The only realistic solution is a program of replacement of ageing pipelines over a period of years - starting with the oldest some of which are over a century old. The problem is that Ofwat will not grasp the nettle and endure the resulting flack from customers whose roads are dug up and water charges raised. Yes, this is going to cost a lot of money! and the cost would not be spread equally over the whole population.
The current approach is to improve the instrumentation on service networks and identify where the flows are greater than theoretical predictions, indicating leakage as well as improved response to reported surface leaks but repair of one leak on an aged system often results in the water finding the next weak spot.
Water is an undervalued resource and fantastically good value at under £1 per cu metre. How much would a similar amount of the bottled variety cost?
Rant over
Ariadne, I'm not saving that invisible leaks aren't leaks - just that they're awfully difficult to locate.
It would cost a lot more than than a few directors' bonuses to pay for replacing the country's water infrastructure.
I'm on side 3 of the fence incidentally
Unfortunately you can only start from where you are. Water shortage has not been a problem in the UK until recently (except 1976) thanks to the overdesign by earlier Victorian engineers and there would have been little appetite for investment in extra storage facilities. With the exception of Carsington and Kielder.Agree, but if a replacement programme for the old pipes had started 30 years ago we would not have had the problems we are having now. In addition more new reservoirs and or desalination plants should have been started to meet future demand. Such a programme of works would have spread the cost and the disruption and could have been done to fit in with other road works as most roads have been dug up at least once in that time.
This is not the fault of the workers on the ground but rather a dismal failure to plan by the bosses of water companies while at the same time pocketing ever increasing bonus'.
Desalination is a last resort IMHO because of the high power requirement of reverse osmosis. We should be looking at distributing the resources from North to South for existing population and discouraging further development in the dry parts of the country. If you can't provide water, you shouldn't build more houses/factories.
Bosses bonuses are a curse of all industries but are insignificant compared with the million pounds per mile cost of new water main.
Is there any understood science, in divination?
Good points - I'm not in favour of large, un-earned bonuses either. However, they have a balancing act between the amount they need to spend on capital schemes and the amount the customers (us) are prepared to pay. If they were to embark on replacing the whole pipe network within a year, the costs would be enormous and would have to come from the customers - where else? There are costs associated with doing nothing, a lot of unscheduled and unplanned isolated repairs, but obviously the pencilnecks see this as the preferred option. In the long term, the whole network will have to be replaced and better to start now IMHO.Agree you can only start from where you are now, but do not think those people who got us there should be rewarded for failure.-
http://www.mirror.co.uk/news/uk-news/water-fatcats-defend-2million-bonuses-782685
"Water fatcats defend £2million bonuses despite 300million gallons lost to leaks every day
Two of the seven firms which imposed bans failed to meet their targets for reducing water leakage – but still handed over large bonuses"
The people receiving these bonus' are not entrepreneurs risking their own money, they are in effect administrators of local monopolies. Their main role is to keep us supplied with water, they are failing.
Perhaps my memory is playing me tricks but am sure I can remember hose pipe bans between 1976 and now?
As you said earlier many of these pipes are over a century old, many are leaking, it should not have taken a genius to work out it will not get better on it's own.
This is not an attack on you but rather those that have failed in their basic duties and are being rewarded for it. They are then putting the onus on the public to get them out of the mess they created. It would be nice if they took responsibility and refused all bonus' until they have fixed the problems.
. . . we ought to limit all freshwater use, the way we do aboard yachts!
