BobnLesley
We have been trying and failing to remove a leaking diesel tank from the boat, which has been installed by simply wedging it tight into the bilge void (we''ve a long keel) behind the ballast area; I'm sure someone thought it a good idea at the time; there's no base/platform below it, nor any wedges/battens to the sides, just an 'interference fit against the fibreglass and ten years of pounding in big seas with a 100kg of fuel inside to wedge it ever tighter. After several hours work we managed to get enough access to the rear of the tank, to drill a hole into it, fit a hook into said hole and connect that with a rope to the mainsheet and that onto a sheet winch. Still no joy, we cranked it until the 8mm rope (admittedly an old one) snapped without achieving any movement whatsoever. We're hauling out in a few weeks time, so if we were to repeat the exercise once ashore, is the removal of the outside water pressure likely to have any significant effect on our efforts?
