FullCircle
What you need is a permanently employed deck hand.
I can cook, steer, and if pushed will buy a round - do I get the job
Hmm, dunno, you unemployed have got a bad name.
But as you will buy a round, the job is yours.
Other than when racing, I find hours at the helm to be boring, so the autopilot is used all the time under engine and most of the time under sail.
I find hours at the helm to be boring, so the autopilot is used all the time under engine and most of the time under sail.......
But then its all in the mind / personal preferences. I leave the helming to the autohelm but much prefer old style nav with paper charts to the chartplotter we have.
+1
I fid Biscay and some other long trips often a bit like watching paint dry - utterly boring.
the captain was never the helmsman, but would sit in his cabin and be enigmatic.
Met a delivery skip who carries a CPT on all deliveries and has fitted it twice in mid ocean.
Uses a Bosch wiper motor I think.
Back in prodution according to the web site.
Also see http://www.csyowners.com/forums/index.php?topic=98.0
I dont know a precise figure but its in the 2 to 3k region for the complete set up inc the computer bits. But I have had tiller pilots and several wheel pilots and this system is by far the best I have had. To put it another way, if I were speccing up a new boat there is no question but that I would go for this pilot again and if I had to economise, it would be on something else.
Other than when racing, I find hours at the helm to be boring, so the autopilot is used all the time under engine and most of the time under sail. But that depends on what sort of sailing you do. Mine involves some longer distance coastal trips , crossing the channel etc but no blue water. If I were just going out for a couple of hours and returning to base then I guess the pilot would not get used much.
But then its all in the mind / personal preferences. I leave the helming to the autohelm but much prefer old style nav with paper charts to the chartplotter we have. Other people will no doubt helm all the time and rely on the chartplotter.
Read the features here & take an educated guess.It's quite expensive compared to the Raymarine and with less features - is it significantly better built?
It doesn't matter which pilot you have the one thing none of them can do is anticipate and stop a turn off course before it starts. The advantage of a quadrant fitted linear drive must be that it can put more rudder on faster than can a wheel drive.
We had a Raymarine ST6000 on our last boat that came with it and went with it after we added another 10 years and 18,000 miles, still going strong. Before that it had done the AZAB and out to the eastern Med and back. We also had an AH4000 backup, wired in with a control head in the pedestal array and an inline plug/socket connection to the wheel drive so that the mechanism was kept down below for fitting only if needed (which required removing and replacing the wheel) which it never was.
It's used on quite large yachts too.
TBH, I doubt whether the standard British yottie would risking buying such a unit as it's an unfamiliar product from a relatively unknown US manufacturer.
When my Neco eventually gives up the ghost I'll probably get one (if they are still made ).
PS: I also have a tillerpilot on my Hydrovane for back-up.
So you really want to able to set a course on the chartplotter & have the autopilot follow it?Well, I would risk buying one, but it does not have any NMEA input to allow it to be driven by a chart plotter and it is quite a lot more expensive than the Raymarine equivalent that does have NMEA, so it would need to be a lot better built to justify the price.
