lw395
If you don't do it often, your guess of 1% can be miles out. It only takes one job to stay sticky and suddenly measuring 1 or 1.5% seems a good idea. If you do it all the time, you probably know what 1% looks like.I always line up a few extra jobs if I have any epoxy left over.
As far as catalyst for polyester is concerned I would never use a measure because the amount of catalyst you require depends on:
How much to use?
- The amount of resin you are planning to use. and
- The ambient temperature. You might need 25ml in early morning when it is cool but only 15 ml later in the day when it is warm. I just use judgement.
We usually express this in terms of percentage ie:1% catalyst to resin = 10ml of catalyst to 1kg of resin. A rule of thumb for polyester laminating resin is between 1% and 2% i.e. 1% for summer (to give maximum wetting time) and 2% for winter (Fiberglassresinsales)
