vyv_cox
Vyv,
what do you mean by "weld as longs as the wire diameter"?
It was an attempt to avoid the problem of the one sample that failed quite badly. It looked very nice, shiny galvanising but the weld was unusually short, perhaps 2 mm wide in an 8 mm chain. It failed in the tensile test and in my bench test. Where the weld is wider, around 6 - 8 mm, it probably shows that the weld has been made well with adequate melting of the metal each side of it. This may be slightly misleading because the weld is trimmed after it is completed, but it is the only observation we can go on.
