vas
Thanks mates. Will try.
Here you reminded me one more question: where can I discharge the diesel water mixture? I keep all that 40+ L bilge mixture liquid in three containers on land. I will never discharge them to the river. Where can I discharge or recycle them to?
try putting them in 20lt transparent plastic containers (like the ones you get the ready mixed antifreeze in for example)
Let the mix settle for a day, notice how much (or how little) the diesel is on top, get a pump with a longish pipe in the bottom of the tank and suck out and discard the water at the bottom. That should be nice and clear and IMHO could go back to the ground.
Get another can and pour the diesel (hopefully with only a little bit of water left in)
repeat until you empty your 3X40+ l containers and you hopefully end up with less than 20L of diesel.
Then up to you, could even add biocide and pour it back in your tanks once the leak is identified and fixed.
good luck
cheers
V.
