Navatech
New Member
Part is straightforward, to the diverter valve for the black tank, but I reckon the main 4.5m run was put in place, and then the boat was built around it.
Not that hard really (unless step # 1 isn't doable):
- Make sure the old hose isn't regidly connected along its line. If it is, release the connections.
- Get a double sided barbed hose connector.
- Remove the old hose from one end.
- Connect the new hose to the old hose using the double sided connector. Use at least double if not triple bands. Wrap the whole double sided connector assembly (I use 3" duct tape) to prevent snagging.
- Go to the other side of the old hose and use it to pull the new hose.
- Reconnect any connections undone in step # 1.
- Cut the new hose to size and reconnect (both sides).
