Tim Good
How many Amp hours do you have in your house banks bank and what type of batteries do you have?
6 X Trojan T 105 golf cart batteries.
Gives me 675 ah. Enough to run the fridge and lappievfor two days plus with no sun.
While it is always useful to know what others have, just that knowledge in isolation is not a lot of help as there are so many other variables to consider such as typical daily consumption, charging capability, space available etc when deciding for your boat.
Think it is reasonable to say that a cruising boat in the 38-45' range aiming to be self sufficient for fairly long periods is likely to need somewhere in the region of 4-600AH capacity and as much solar as can reasonably be fitted on the boat (plus possibly wind or towed) and for boats at the upper end possibly a generator.
Likewise the choice of battery type varies according to preference and depth of pocket
So perhaps more important to understand the reasoning behind the choices of others so you can assess how they relate to your situation. Making choices is difficult particularly when there are so many options and you don't have that depth of personal experience to draw on.
Good and fair advice.
For a decent solar controller like our Victron, when it says it is at float how likely is it that the battery are actually full? Or does it need to be at float for a good while to guarantee they are tipped up?
The fridge is programmed to only come on when the voltage is 13.something, and switches off when it drops below 12.8. Typically it works from 9:30 till 18:00. Stuff is still cold in the morning.
