Angele
Did that once. It's a very easy way to split a mainsail!
But, at least it stops the gooseneck disintegrating as the boom smacks over to the other side - probably beheading one or two crew members as it goes.
But, at least it stops the gooseneck disintegrating as the boom smacks over to the other side - probably beheading one or two crew members as it goes.![]()
BTW tying a rope from boom to bow is not how I'd rig a gybe preventer , I'd rig it end of boom through bow cleat or similar and then back to a sheet winch, I then grind it in hard and in opposition to the mainsheet the boom ain't going anywhere until I release it off the sheet winch. Why don't you try that method yourself sometime?
It might or might not. In ideal circumstances it will hold long enough that the problem goes away, or even better will slow the boom as it goes accross the boat (there are braking devices on the market for this).
Sadly physics is not on your side here if you have a sailboat since it's pointy at the front, meaning that you cannot get a useful angle to stop the boom from moving completely no matter how tight you winch that handle. The forces required, thanks to this angle, are greater than most ropes could cope with so more than likely your rope will snap and the boom will be moving even faster. If you use rope strong enough to not snap, your deck fittings will probably rip out and then you have a boom followed by a projectile.
The reason I continue arguing on this is precicely because people such as Angele believe the rope will stop the boom moving - it won't. Far better to educate people on the real use of the piece of rope and where it helps and when it's likely to fail. When at sea having the best information is more important than the best kit.
Thanks for that sarcasm. Have you considered that where the rope goes from the bow makes no difference to the physics of it being able to hold the boom? In fact you're more than doubling the length and therefore stretch of your rope making it more likely to allow the boom to move.
Keep cranking the winch though, you may just get it tight enough before the bow cleat rips out of your deck and gives you a nasty head injury.
A Boom preventer does not prevent Gybes and is therefore not called a Gybe preventer. They are there mainly to stop the banging of the boom from the motion of the ocean and in no way help with accidental gybing.
The only time they actually do prevent Gybes will be when you're too close to the land and need to Gybe but can't because you tied the boom in place!
Cheers
Dave
My sentiments entirely....t preventers have been called all sorts I'd things over the years and whilst they can't stop you gybing if you are really careless, they DO make sailing by the lee less hazardous if you stray off course as you roll down the swell. Perhaps for the pedants we should start calling preventers Gybe discouragers - but I am not serious. ....
..... It's a safety measure and so long as it's braved up nice and tight and lead back to the cockpit we can alter to any point of sail very quickly.
Hi Jimi, I went mackerel fishing today and reeled in quite a few big ones. You seem to have had similar success.![]()
HAving the gybe preventer line led back to the winch meant it was easily released and horizontality could be regained ;-)
