Nicholas123
N/A
Mine seems to totally disintegrate in one year & I am wondering if this means it is a viable solution & practical application for protecting my prop.Maybe a different metal like aluminium would be more satisfactory?
Not sure about the validity of the previous suggestions to fit a larger anode or to fit two. You may be able to do that with shaft anodes but can you do that with prop anodes.
I had assumed it was a shaft anode. Now looking at the OP's bio it refers to an old boat.
He has a Macwester 27 fitted with a DV10. ... but no phone!Would have been nice if he'd thought to mention what kind of stern gear he has, wouldn't it
So probably no room for additional shaft anodes .. possibly not even room for one of the slim collar type ones, so a hull anode might be the solution.
However if he has a decent manganese bronze fixed bladed prop it probably does not need any cathodic protection anyway!
A year is quite reasonable if it is just one of those little buttons on the end of the prop. Better that than your propeller dezincifying.
Best way to increase anode capacity to increase the length of time before replacement is to fit a hull anode bonded to the prop shaft, probably through the gearbox casing. You may also need to bridge the coupling if it is the flexible type. More information on fitting anodes on the MG Duff website.
Well done Sherlock,you have correctly identified me & I still don't use a phone to contact people who advertise on the internet but cannot be contacted by it
Sorry.
Apologies but it is a shaft anode,I did'nt know props could have separate anodes.The one I put on last year was about 1/2" broad & had about 3/4" meat around the circumference.It did'nt so much erode as completely disintegrate.
I think I can fit a neater looking one in the 1 3/4" gap I have got on my 25mm shaft directly behind the prop but will it last any longer?
Interesting to know that if my prop is good quality manganese bronze it would be ok but is it & how can I tell? I think it's good quality because it looks old & unblemished but it could be phosphor bronze or some other kind of derivative could'nt it![]()
The fact that the anode is eroding suggests something is going on between the shaft and the prop so would be unwise to omit an anode. .
It does not follow that anything beneficial is going on
