I read a post a while ago about the best ways to search the forum. I find that I can only search posts up to one year old. I know there is a way to get google to do it. Any hints?
The internal Search facility will search back beyond 1 year but it will only do a year at a time so if you put in "older than 1 Year" it will find results between 1 and 2 years old.
I cant make PVB's suggestion work. In Google I use YBW + keyword
You're not putting any spaces in the site:www.ybw.com/forums bit, are you? That would stop it working properly. There should be a space after forums, before the first search word. It's a standard Google method of searching only within a particular website.
[/ QUOTE ] That worked but it only came up with 6 results. Oxalic acid has been mentioned on the forums countless times so why does it only find 6 of them.
I actually searched for muriatic acid, which is mentioned nearly every time blocked toilet hoses are mentioned including one current thread. I got no matches at all!
I faired a lot better with the internal search getting several matches for each of the years I searched.
FWIW I have the google tool bar which has a search this site button.
On "Oxalic Acid" it returned 209 hits.(which probably still understates the number of posts on the subject!).
Have to agree.... the google search showed up 4 hits, yet using the forum search with just the word muriatic, and "older than 1 month" gave 17 posts. /forums/images/graemlins/confused.gif
Ive always used the google method. Everytime i serch within the forum, its says something like 'another search cannot be performed at this time' or something similar.
once you've done a search, there is a time limit that stops you doing any more searches immediately to stop overloading the server as they are very intensive and can slow the server down for the rest of users if too many of them. Just wait a little while and try again
or alternatively, "right click" on search to open it in a new tab/window, do the search, and if nothing shows up, close the tab/window and then "right click" again......
It works better without the / between ybw.com and forums
[/ QUOTE ] Strangely, it does return many more results, yet they're still mostly results with URLs starting "www.ybw.com/forums/....". Don't understand why Google is working that way.
When I first started using Google (because the standard forum search was so incredibly slow), I just used site:www.ybw.com but found that I got a lot of non-forum results, hence I started putting site:www.ybw.com/forums to be more specific.
