Wansworth
In most Galician villages you will find a covered washing place,replet with running water and a two tie wash.there used to be women about washing but we now have washing machines.....
Wonderwash, a manual machine that we have owned for many years. We have done two loads with it this morning, another two scheduled for this afternoon. That's after about five weeks aboard, so not too onerous. Needs two buckets of fresh water per load for rinsing but apart from the soap, it's free.
Is that a little red thingy with a lid that you turn with a handle and cleans with a buildup of pressure,.....theres one in my shed
Well, ours is white, but otherwise it sounds like the same thing. Takes about 2 kg per load in 6 litres of water, turn for 2 minutes, then rinse in buckets. My laundry adviser reckons it washes cleaner than our Whirlpool at home.
It would be interesting to find out how much water you are using for the rinsing![]()
I picked up a useful water-saving washing method which is used a lot by US long distance cruisers.
You need household ammonia - easier to buy in the US than here but Dyas and B&Q have it.
Get a bucket of hot water, add a cup of ammonia and give your stuff a good soak and stir around a bit.
All you have to do then is hang them out to dry. The residual ammonia evaporates and leaves no trace behind. And, most importantly, it has killed the bacteria which is what makes clothes smell.
There's no need for rinsing and you can save a huge amount of water on a long passage.
Of course, it's not detergent so don't expect the 'whiter than white' result
Large plastic container with handles that are sold to gardeners and plasterers for unknown purposes. Put in washing water and soap. Stand in container and start walking on the spot. Best timing mechanism is a cigarette. One unforseen problem of giving up smoking is that one might end up washing forever. Wring out clothes - stand on one end and twist. Fill with fresh water and repeat. After doing the wringing you will feel like another cigarette. Repeat until clothes are rinsed enough or you need to go and buy some more cigs. Only works in warm countries where cigarettes are cheaper than laundries.
