How Do These Come Off?!
Also, you can post photos here by clicking on the Img box in Photobucket which copies it and then pasting it into your post. Just be sure to make sure it is not oversize or you will get complaints.
Here's a pic from Hella's catalogue - the yellow arrows indicate the bayonet action.
Brilliant thanks. Got some strange sh** going on with my mast lighting... There's a three core cable going up - a common ground and two supplies. At the mast base, my ohm meter shows continuity between ANY two of the three! Can't be right!
That'll be right.
Common negative. and two positives, one for each bulb
You will see continuity between all three if both bulbs are good.
but the resistance between the two positives will be equal to the sum of the resistances between the negative and each positive. ( double if both bulbs are the same power)
I think i'm getting the picture, but electrics was never really 'my thing'.
Another question then please guys... With all wires DISCONNECTED from supply and ground, how do I determine which of the three mast wires is the common earth? I'm guessing the lamp fittings will be designed so that it matters?
I really appreciate your time and patience;-)
With bulbs in place
Measre the resistances between all the wires
3 readings ... got it.......
one reading will be higher than the other two
The high reading is between the two positives .... so the other wire is the common negative
With bulbs in place
Good god Vic.... Do you ever sleep or do anything else? ;-) Seriously, thank you! I thought that's what I'd understood from your earlier post, but my relationship with 12v electrics is about the same as that with horses, so it's always as well to TREBLE check;-)
Filament bulbs have a peculiar resitance when cold. Always a lot lower than when hot. So a 24 watt bulb draws 2 amps on 12v so 6 ohms.(hot resistance) However when you measure it is may measure something more like 3 ohms. (cold resistance) Hopefully you can on a 200 ohm scale on Digital multimeter read the low ressitance and hence discern the +ve wires for the lamps. good luck olewill
The cold resistance of the bulbs may be very low.
I have a 12V 20W halogen here, it's showing <1ohm.
So can be hard to detect with a meter, allowing for long wires and a bit of contact dirt.
It's normal to use mains 3 core cable. Most people use the green/yellow earth as 'common', but some might use black or blue.
If you pick two wires and put 12V on them, and both bulbs light, a bit less bright than normal, the other wire is the common.
Assuming filament bulbs not LED....
