It could well be on a tapered shaft. The only way I have ever budged one easily is with bearing extractors. So much so that I now own a set(?), borrow from a local garage may be a good option.
Hope this helps.
should be on a tapered shaft with a keyway ! don't loose the keyway when you get it off.... gentle use of a copper mallet may shock it or waggle the wheel. you ideally need a puller !
Try tapping all round the boss from behind while some one else pulls the spokes steadily. As others have said, probably a taper shaft & if the taper is shallow, overtightening the nut can force it to stretch the boss & compress the taper. Careful heat application may also help - but don't let it glow red hot!!!
Pullers are the best solution, you may be able to get one from a tool hire company.
If you can't get a puller, make three tapered wedges from wood and put them equidistant from each other between the wheel boss and the front face of the pedestal boss and tap each in turn gently whilst pulling on the front of the wheel. As the pressure increases it will release.
It's a 1:12 taper, if it's a tapered shaft. The thing that worries me is that it MAY be a straight shaft, which is a swine to get off, especially with dirt, salt and old-age getting into the hole in the wheel.
Don't just slog the wheel off from behind in either case- you'll probably toast the circlips that hold the shaft in the boat. And be careful of the spokes- they're not really designed for levering in any direction except to rotate the shaft. I've seen a number of failed wheels from over-eager removal!
Sorry bout the pessimism- it's not really such a bad thing: with WD40 and enough tea, and a good bearing-puller, it's easy!
You can make a puller if you are handy with metal and have a drill press.
Basically you need a piece of steel about 10mm thick square or circular about 15cms across. In the center of this you drill a hole to take a bolt at least 10mm diameter. You weld a suitable nut on one side of the plate to take the bolt. The bolt is screwde from the hole side and must have enough thread about 50mm would be good.
The bolt is screwed down to press onto the shaft now all you have to do is figure a way to attach the plate to the steering wheel.
U bolts one around each spoke might work if the spokes are strong enough. Or make up pltes that will slife under the boss with a bolt at each end. Or you may be able to use individual bolts with a hook bent into the ends to hook under the boss. The plate should be heavy enough to take many holes in various positions for different fixing methods.
Set the plate up then tighten the center bolt onto the shaft. Often a swift hit with a carefully calibrated bashometer on the head of the center bolt will help dislodge the wheel. good luck olewill
SPRAY dW40, 556 etc +
TIME +
SPRAY dW40, 556 etc+
PULLER AS SAID! +
SHOCK THE TAP/AXEL MODERATELY WITH HAMMER IF POSSIBLE KEEP THE LOOSENED NUT ON TO PROTECT WINDINGS +
IF NOT LOOSING TRY WARMING THE WHEEL AND COOLING THE AXEL + THE ABOVE PROCEDURE - NOW WITHOUT TEA TIME! +
NOW IT WILL COME OFF - CAREFUL AS SAID NOT LOOSING ANY PARTS /forums/images/graemlins/grin.gif
Thank you all for your replies. I wanted to take the wheel off as we had some people over the other night. The first two guests undid the nut and pulled it off between them! Must have been me loosening it first that enabled them to do this of course /forums/images/graemlins/wink.gif
