tudorsailor
I have acquired a towed generator. I have now read the maintenance instructions (as suggested to me on a propr thread!) It says......
If the cogging or breakout torque has been correctly minimised, the resistance to revolution should be no more than 2kg-cm (30oz-inch).
Is it too simplistic to try and attached a rod to the spindle and apply less than the max torque and see if it turns. 2kg at one cm is difficult as the distance is so small. If i make a 10cm rod, am I right that it should turn with a weight of less than 200gms?
TudorSailor
TudorSailor
