Otter
To get the correct angle I placed the fitting on the outside of the hull, outside of the fitting flat to the grp with the exhaust pointing down, then your angle is the same as the exhaust, line up pilot drill alongside the exhaust and away you go.
Sounds more complicated than it is.
Please don't use a multi cutter tool, buy the correct size from someone like Axsminste.r I use the Bosch range and over the years have built up a collection. They all use the same quick change arbor.
Thanks - sorry to be a numpty but dosen't the exhaust angle upwards so that water can't flow down into it?
