Boater On Thames
Just viewed an old 1995 Princess 480. Found engine oil leaking quite a lot. Also found the two engines outside a few inches is the fuel tank so there is not possible to see or fix the outside of the two engines without removing the engine. In this case, the only way to check and fix it is to remove the two engines. How difficult will that be? Feel not right if every repair needs to remove the engines. What do you think? Thanks.
