ytd
you are both right. A snuffer on a 7m boat does sound like overkill even single handed. But there is no way I would try and fly our 120m2 cruising kite without the snuffer or a crew of 4. In lighter winds it is almost impossible to gybe without wrapping it around the furled genoa so we snuf it, throw the sausage around the forestay and then unsuf. Another benefit is that we can drop the sausage directly into the sail locker rather than haul a wet sail into the forecabin for later bagging. Our snuffer is about 40cms dia with a plastic hoop tapering to about 10cms at the top. There is a wire lead of about 20cms between the top of the sail and the halyard and this is where the snuffer sits when the kite is flying. Another observation on cruising kites is that there are much higher shock loading on the sheets than with a conventional kite. It seems the pole and braces supply a lot of shock absorbency with a conventional kite.
