itsmeagain
New Member
Just discovered bilge full of hot water and the freshwater tank empty. It’s a Jeanneau SO37. Anyone had a similar experience?
Unless he's done some modifications the SO37 only has a cold water feed at the transom.Hot water pipe popped off our transom shower only a couple of weeks ago now. To start with we couldn't work out why the pump kept going and then we ran out of water. A quick check found hot water in the bilge and a red water pipe hanging down from behind the transom shower.
Mine has hot and cold. I used it after a dip in the Solent on SundayUnless he's done some modifications the SO37 only has a cold water feed at the transom.
It is obvious to all on board when our FW pump operates. One guest even took it upon himself to switch off the pump when he slept in our aft cabin in case it purred during the night. In practice, it’s not that noisy, but I might overlook it if the engine were running.I had the hot feed pop off the calorifier and so the whole tank of water deposited in the bilge - handy for cleaning. My nightbour had a Princess 32 and built in the dashboard there was a red light which lit whenever the domestic pump operated. It seems to me to be a very sensible and convenient arrangement. I shall be fitting one this winter. And I shall fit a similar light showing if the auto bilge pump is operation. I want to link that to an event monitor so as to show when we are away. At the moment I cannot find a neat event counter.
Ours is much less noticeable after we fitted a 2 litre expansion tank after the high capacity pump, minor water use doesn't even turn the pump on until it feels it really must top up the pressure. me cleaning teeth doesn't turn it on, milady washing hands however at full on does but temperature relief on calorifier at most does a little2 second or so run rarely audible even in quiet of nightIt is obvious to all on board when our FW pump operates. One guest even took it upon himself to switch off the pump when he slept in our aft cabin in case it purred during the night. In practice, it’s not that noisy, but I might overlook it if the engine were running.
Many thanks!
